The Draw surface not working inside a Windows Touch SurfaceWindow
905
05-15-2011 01:15 PM
Joachim_EckboJuell
I'm trying to use the Draw class inside a Windows Touch WPF Surface application (a SurfaceWindow), but I can't get it to work. I'm trying out the code from the samples, creating the Draw object, setting the draw mode and enabling it. But the map just continues to be in navigation mode.
I'm using the 2.2 Beta. Any clues?
-JJ
JenniferNery
Can you try running this SDK sample? http://help.arcgis.com/en/webapi/silverlight/2.2/samples/start.htm#DrawGraphics
You should be able to draw using touch (Tap, DoubleTap) instead of (MouseLeftButtonDown, double-click).
