TextSymbol text looks very offset on zoomed out position
3306
02-21-2013 11:35 AM
LuisGarcia2
Take a look at the attached screen shots, on the one on top the text looks somewhat offset but it is fine and actually preferable considering that we need to be able to read those. The one underneath looks rather offset, to the point that it seems like the points are in a totally different position. Basically they don't stay with the other marker. Is there a way to control that?
Thanks!
DominiqueBroux
Esri Frequent Contributor
By default, when using a text symbol, the location of the node is the upper left corner of the TextSymbol.
You can change that by setting an OffsetX and OffsetY to your text symbol.
That being said I am not sure that will solve your issue. The offset will still be the same whatever your map scale (note that the offset is in pixel not in map coordinates).
I guess what you would need is a label engine that would try to avoid overlapping labels but this doesn't exist at client side yet.
DominiqueBroux
