Tap into the Map Extent Changed event from a custom control
1252
07-20-2011 05:57 AM
JasonCleaver
I need to create a custom UserControl that can respond to the Map_ExtentChanged event.
In my class I have the following code:
public static readonly DependencyProperty MapProperty = DependencyProperty.RegisterAttached(
            "Map",
            typeof(ESRI.ArcGIS.Client.Map),
            typeof(NavigationWidget),
            new PropertyMetadata(OnMapPropertyChanged));
public Map Map
            get { return GetValue(MapProperty) as Map; }
            set { SetValue(MapProperty, value); }
private static void OnMapPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
            ((NavigationWidget)d).Map.ExtentChanged +=new EventHandler<ExtentEventArgs>(Map_ExtentChanged);
private static void Map_ExtentChanged(object sender, ExtentEventArgs e) {}
Did I implement this right?
Jason
DominiqueBroux
Esri Frequent Contributor
At first glance it looks correct.
Do you get some problems with this implementation?
JasonCleaver
Thanks.
The problem I had was accessing the class objects within the private static void Map_ExtentChanged(object sender, ExtentEventArgs e) {} method.  I eventually figured this out.
Jason
