TabbedRibbon Blend Effect
1027
12-09-2010 07:16 AM
DavidAshton
I am messing around with the TabbedRibbon template and I'm just trying to change the look and feel (colors) in Blend 4.
By changing the TabbedRibbonBackgroundBrush I can change the Ribbon colors and by changing the CommonPanelBorderBackgroundBrush I can change the outside brush of the userControls:CollapsiblePanels
But how do I change the inside color of the userControls:CollapsiblePanels (about, overview, and datagrid windows)?  -- currently the inside is gray.
Also how do I change the colors of the three tabs (view option, navigation, query) - these are currently gray when hoovered over they turn darker black/gray blend.
It seems like it is the same resource but I can't seem to find it.
David
JenniferNery
Notice that for each CollapsiblePanel in the MainPage, contains Borders within their container Grid. The Border's either define a Background or Style.
You can update CommonPanelBorderBackgroundBrush Background and RibbonElementBorder Style. In this Style, you may want to update the Setter for BorderBrush and Background.
DavidAshton
Jennifer,
Thanks for the post.  I think I have figured everything out! EXCEPT:mad:
Changing the color of the tabs (View Options, Navigation, Query).  I can change the color of the Gradient Bottom (when Unselected and Hovered) but I can't seem to change the color of the tab when it is selected or click (in focus).  If I change the FocusVisualBottom I can kind of get it but that is not it.
Any insight on how to change the color of the select/focused tab(s)?
Dave
