Symbol Covering Progress Bar
1397
09-19-2012 06:14 AM
JannalynPontello
I have a progress bar on my Silverlight web map that is being covered by a plus symbol in the center of the map. I'm guessing the symbol is built in somehow, because I never added it. I need it to go away because users cannot see the percent complete on the progress bar, but I don't know where it's added. I checked the ESRI templates that can be downloaded and noticed one of them didn't have the symbol on the map, but I can't figure out what's different between that template and my own app. Any ideas?
LanceCrumbliss
there is probably a couple of lines like
                    <Rectangle Width="2" Height="10" Fill="Black" Opacity="0.75" HorizontalAlignment="Center" VerticalAlignment="Center" IsHitTestVisible="False" />                     <Rectangle Height="2" Width="10" Fill="Black" Opacity="0.75" HorizontalAlignment="Center" VerticalAlignment="Center" IsHitTestVisible="False" />
somewhere in MainPage.xaml.  Remove them.
Lance
LanceCrumbliss
Lance
JannalynPontello
If I remove them, then I lose the rectangle that draws when users zoom in and out. My website will be used by an older audience, so I need them to show up. Do you know if I can apply an attribute to the xaml so that the plus doesn't show? I'm not a programmer by trade, so it's at least good to know where the symbol is coming from.
LanceCrumbliss
my guess is that you removed the wrong one(s).
And yes, you can make the cross-hair visible/collapsed by putting it in a grid and binding it's visibility to a property (and implementing INotifyPropertyChanged) in the code-behind.  You may need to use a ValueConverter to convert from Boolean to Visibility, depending on how you want to do it.
Lance
JannalynPontello
You were correct orginally. I somehow removed my ZoomFillSymbol, so it looked like removing those rectangles caused an issue. I wonder why they were even there to begin with, because my site works perfectly. Thanks for your quick help.
