Suspend map drawing
1565
10-19-2011 06:21 AM
SteeveCouture
Is there a way to disable (or suspend) the map drawing during a moment? By example, if I unselect 500 elements of 1000 elements for a GraphicsLayer, that operation is very long (there's severa refresh).  May be, a workaround is to set the GraphicsLayer not visible.
An another example is if I add some layers (like 10) in map control, could I disable drawing to avoid to add to much redraw for each add?
What is the best pattern?
Steeve
JenniferNery
Are you using Draw class as shown in this SDK sample? http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#DrawGraphics. If yes, Draw.IsEnabled=False or Draw.Mode=DrawMode.None will disable draw.
SteeveCouture
No, sorry.  I don't talk about the Draw object.  I mean to suspend the Map refresh when I change the Graphic element state (like Selected property) in GraphicsLayer. An another example if I remove 500 Graphics from GraphicsLayer (total count is 1000), it's very long because I thought there's lot Map refresh.
I'm perhaps not clear.
Steeve
JenniferNery
What version of the API are you using? Can you share some code and steps to reproduce this? I don't understand why selecting/deselecting graphics from GraphicsLayer will cause a re-draw on the map. Could you perhaps been calling layer.Refresh() in your code? Map triggers layer.Draw when pan/zoom is completed, map size changed, layers initialized.
