Stroke on a line symbol
2009
06-02-2011 03:52 PM
DonFreeman
Is there a line symbol type that allows you to put a border (stroke) around the line to provide enhanced definition? Is there a sample somewhere?
Thanks
DominiqueBroux
Esri Frequent Contributor
A line symbol uses the path stroke property to define the main color, so it's not possible to get a border to the line with only one path element.
One approach might be to define a symbol with many paths having various colors and thicknesses.
Something like:
<esri:SimpleLineSymbol x:Key="myExtendedLineSymbol" Color="Blue" Width="10" >
    <esri:SimpleLineSymbol.ControlTemplate>
        <ControlTemplate>
            <Grid>
                <Grid.Resources>
                    <local:CloneGeometryConverter x:Key="cloneConverter" />
                    <esri:MultiplicationConverter x:Key="multiplicationConverter" />
                </Grid.Resources>
                <Path x:Name="Element" Stroke="{Binding Symbol.Color}" StrokeThickness="{Binding Symbol.Width}"
                        StrokeEndLineCap="Round" StrokeStartLineCap="Round"/>
                <Path Stroke="White" StrokeThickness="{Binding Symbol.Width, Converter={StaticResource multiplicationConverter}, ConverterParameter=0.6}"
                        Data="{Binding Path=Data, ElementName=Element, Converter={StaticResource cloneConverter}}"
                <Path Stroke="Red" StrokeThickness="{Binding Symbol.Width, Converter={StaticResource multiplicationConverter}, ConverterParameter=0.2}"
            </Grid>
        </ControlTemplate>
    </esri:SimpleLineSymbol.ControlTemplate>
</esri:SimpleLineSymbol>
which gives the attached screenshot as result.
Important note : I am not sure this approach is fully supported by ESRI because the root element of the line symbol is not a path. So despite it looks working well at first glance, consider this as an unsupported approach without any ESRI guarantee.
You will also need code to clone a geometry (without cloning it we get a crash).
Here is the code I found on the Web:
public class CloneGeometryConverter : IValueConverter
    public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
        if (targetType == typeof(System.Windows.Media.Geometry) && value is System.Windows.Media.Geometry)
            return Clone(value as System.Windows.Media.Geometry);
        return value;
    public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
        throw new NotImplementedException();
    // Code coming from http://kiwigis.blogspot.com/2010/06/cloning-path-geometry-in-silverlight.html
    private static object Clone(Object obj)
        // Get all properties and clone them.
        PropertyInfo[] properties = obj.GetType().GetProperties();
        object cloneObj = obj.GetType().GetConstructors()[0].Invoke(null);
        foreach (PropertyInfo property in properties)
            object value = property.GetValue(obj, null);
            if (value != null)
                if (IsPresentationFrameworkCollection(value.GetType()))
                    object collection = property.GetValue(obj, null);
                    int count = (int)collection.GetType().GetProperty("Count").GetValue(collection, null);
                    for (int i = 0; i < count; i++)
                        // Get each child of the collection.
                        object child = collection.GetType().GetProperty("Item").GetValue(collection, new Object[] { i });
                        object cloneChild = Clone(child);
                        object cloneCollection = property.GetValue(cloneObj, null);
                        collection.GetType().InvokeMember("Add", BindingFlags.InvokeMethod, null, cloneCollection, new object[] { cloneChild });
                // If the property is a UIElement, we also need to clone it.
                else if (value is UIElement)
                    object obj2 = property.PropertyType.GetConstructors()[0].Invoke(null);
                    Clone(obj2);
                    property.SetValue(cloneObj, obj2, null);
                // For a normal property, its value doesn't need to be                // cloned. So just copy its value to the new object.
                else if (property.CanWrite)
                    property.SetValue(cloneObj, value, null);
        return cloneObj;
    private static bool IsPresentationFrameworkCollection(Type type)
        if (type == typeof(object))
            return false;
        if (type.Name.StartsWith("PresentationFrameworkCollection"))
            return true;
        return IsPresentationFrameworkCollection(type.BaseType);
DonFreeman
Thanks Dominique. Where does the c# code go? I placed it at the end of my mappage codebehind but the xaml code doesn't see it there even after a build.
DominiqueBroux
Where you want. Your MapPage is OK.
You have just to look at the namespace of the class and check that your are using the right namespace in XAML i.e.
<local:CloneGeometryConverter local must match the namespace of 'CloneGeometryConverter' in your code.
DonFreeman
Thanks Dominique. I got it working. My problem was the local reference in the xaml code.
