Sql 2008 spatial data on WPF map control
1414
10-14-2011 10:52 AM
ApurvaGoyal
I have an application with WPF Map control and Bing Maps as base map. Is it possible to display some sql 2008 geoagraphy data in this control? I have read other post mentioning MapIt as a way to display sql spatial data in silverlight..but I am not sure if that applies to WPF as well.
Please note that the users of this application will not be connected to internet.
Apurva
JenniferNery
ArcGIS API for WPF and Silverlight are equivalent in that what you can do in one, you should be able to do in the other. WPF also supports SDS, here's an example in Silverlight: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SDSGraphicsLayer. You can download WPF SDK sample from here: http://help.arcgis.com/en/webapi/WPF/samples/start.htm. Also, please try to use WPF forum page in the future so other WPF users can benefit from your questions: http://forums.arcgis.com/forums/131-ArcGIS-API-for-Microsoft-WPF. Thanks 🙂
ApurvaGoyal
Thanks Jennifer!
ApurvaGoyal
Jennifer,
So can user use spatial data service on their local app using local instance of sql express database.
