Spatial Query  in different layers?
2111
02-13-2012 11:49 AM
by Anonymous User
Not applicable
Original User: angelmch
Hello,
I was reviewing the following example to querys spatial
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm # SpatialQuery
In this example uses only one layer. It is possible to query space for different layers? (eg http://sampleserver1.arcgisonline.com/0 and http://sampleserver1.arcgisonline.com/1)
Whereas in some cases that do not have the same attributes.
Thank you very much for the help
by Anonymous User
Not applicable
Original User: diligentpig
Queyr Task is designed for one layer only, this is true. If you want to perform querying across multiple layers at one time, you should using Identify task instead.
Note the LayerIds attribute: http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Iden...
For more information under this tasks, you may want to reference the underlying REST API of ArcGIS Server:
Query:http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/query.html
Identify:http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/identify.html
