Some MapService Layers Query results won't display as graphics layers
8030
15
03-28-2012 04:15 AM
MattMiley
I'm using the find example and when i query my storm map service everything works. WHen i query my water map services i get results in the datagrid but they won't show up as graphics layers when i select them.
Here is the returned Json for Storm (WORKING)
{   "results" : [     {       "layerId" : 0,        "layerName" : "GIS.GISADMIN.StormNodes",        "displayFieldName" : "NodeType",        "foundFieldName" : "OBJECTID",        "value" : "11",        "attributes" : {         "OBJECTID" : "11",          "Element_ID" : "0",          "SOURCE_DES" : "Sanitary Sewer Improvements Contract 10-S",          "Coordinate" : "648444.115, 2060333.176",          "Shape" : "Point"       },        "geometryType" : "esriGeometryPoint",        "geometry" :        {         "x" : -9146569.69071188,          "y" : 5078354.76733345,          "spatialReference" : {           "wkid" : 102100         }       }     },      {       "layerId" : 2,        "layerName" : "GIS.GISADMIN.OutFalls",        "displayFieldName" : "StreamName",        "foundFieldName" : "OBJECTID",        "value" : "11",        "attributes" : {         "OBJECTID" : "11",          "StreamName" : "Black River",          "OutFallName" : "Tacoma",          "Shape" : "Point",          "Type" : "Outfall",          "Name" : "Null",          "Notes" : "Null",          "Notes_1" : "Null",          "Oberservation_Date" : "Null",          "Oberserver" : "Null"       },        "geometryType" : "esriGeometryPoint",        "geometry" :        {         "x" : -9140394.26845358,          "y" : 5078269.86245744,          "spatialReference" : {           "wkid" : 102100         }       }     }   ] }
Here is the returned Json for Water (NOT WORKING)
{   "results" : [     {       "layerId" : 0,        "layerName" : "Hydrants",        "displayFieldName" : "HYDRANTNUMBER",        "foundFieldName" : "OBJECTID",        "value" : "11",        "attributes" : {         "OBJECTID" : "11",          "HydrantNumber" : "H0561",          "Location" : "S.W. CORNER OF BROWNELL AVE.AND WEST ERIE AVE",          "Hyd_Num" : "Null"       },        "geometryType" : "esriGeometryPoint",        "geometry" :        {         "x" : -9149034.62292915,          "y" : 5081286.44737778,          "spatialReference" : {           "wkid" : 102100         }       }     },      {       "layerId" : 1,        "layerName" : "Valves",        "displayFieldName" : "VALVENUMBER",        "foundFieldName" : "OBJECTID",        "value" : "11",        "attributes" : {         "OBJECTID" : "11",          "ValveNumber" : "V4016",          "Valve_Diameter" : "8"       },        "geometryType" : "esriGeometryPoint",        "geometry" :        {         "x" : -9153324.01843533,          "y" : 5077188.05044879,          "spatialReference" : {           "wkid" : 102100         }       }     },      {       "layerId" : 2,        "layerName" : "LateralNodes",        "displayFieldName" : "ENABLED",        "foundFieldName" : "OBJECTID",        "value" : "11",        "attributes" : {         "OBJECTID" : "11",          "Enabled" : "True",          "SHAPE" : "Point"       },        "geometryType" : "esriGeometryPoint",        "geometry" :        {         "x" : -9159684.58115913,          "y" : 5072989.92068145,          "spatialReference" : {           "wkid" : 102100         }       }     }   ] }
Here is a storm layer attribute
Layer: GIS.GISADMIN.StormNodes (ID: 0) Display Field: NodeType  Type: Feature Layer  Geometry Type: esriGeometryPoint  Description:  Definition Expression:  Copyright Text:  Min. Scale: 10000  Max. Scale: 0  Default Visibility: True  Extent:      XMin: 2051575.44395877     YMin: 644699.275933608     XMax: 2071690.73607719     YMax: 657055.237114027     Spatial Reference: 3734  Has Attachments: False  HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText  Drawing Info:      Renderer:         Unique Value Renderer:          Field 1: NodeType         Field 2:         Field 3:         Field Delimiter: ,         Default Symbol:             Unsupported Symbol         Default Label:         Unique Value Infos:             Value: Gutter Inlet             Label: Gutter Inlet             Description:             Symbol:                 Picture Marker Symbol:              Value: Inlet Basin             Label: Inlet Basin             Description:             Symbol:                 Picture Marker Symbol:              Value: Manhole             Label: Manhole             Description:             Symbol:                 Picture Marker Symbol:      Transparency: 0     Labeling Info: N/A  Fields:      OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID)     Element_ID (Type: esriFieldTypeDouble, Alias: Element_ID)     NodeType (Type: esriFieldTypeString, Alias: NodeType, Length: 32 )     NodeNumber (Type: esriFieldTypeString, Alias: NodeNumber, Length: 32 )     Coordinate (Type: esriFieldTypeString, Alias: Coordinate, Length: 30 )     Shape (Type: esriFieldTypeGeometry, Alias: Shape)  Type ID Field: N/A  Supported Interfaces:   REST  Supported Operations:   Query
Here is a water layer attributes, I think something is messed up here
Layer: Hydrants (ID: 0) Display Field: HYDRANTNUMBER  Type: Feature Layer  Geometry Type: esriGeometryPoint  Description:  Definition Expression:  Copyright Text:  Min. Scale: 10000  Max. Scale: 0  Default Visibility: True  Extent:      XMin: 2028056.97998909     YMin: 628506.51000617     XMax: 2077442.1400012     YMax: 662339.880002109     Spatial Reference: 3734  Has Attachments: False  HTML Popup Type: esriServerHTMLPopupTypeNone  Drawing Info:      Renderer:         Unique Value Renderer:          Field 1: Enabled         Field 2:         Field 3:         Field Delimiter: ,         Default Symbol:             Unsupported Symbol         Default Label:         Unique Value Infos:             Value: 0             Label: False             Description:             Symbol:                 Picture Marker Symbol:              Value: 1             Label: True             Description:             Symbol:                 Picture Marker Symbol:      Transparency: 0     Labeling Info:         Label Placement: esriServerPointLabelPlacementBelowCenter         Label Expression: [HYDRANTNUMBER]         Use Coded Values: True         Symbol:             Simple Text Symbol:             Type: esriTS             Color:255, 0, 0, 255             Background Color: null             Border Line Color: null             Vertical Alignment: bottom             Horizontal Alignment: center             Right To Left: False             Angle: 0             XOffset: 0             YOffset: 0             Font Family: Arial             Font Size: 8             Font Style: normal             Font Weight: bold             Font Decoration: none         Min. Scale: 0         Max. Scale: 0  Fields:      OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID)     HydrantNumber (Type: esriFieldTypeString, Alias: HydrantNumber, Length: 16 )     YearInstalled (Type: esriFieldTypeInteger, Alias: YearInstalled)     Manufacturer (Type: esriFieldTypeString, Alias: Manufacturer, Length: 32 )     Hyd_Num (Type: esriFieldTypeInteger, Alias: Hyd_Num)  Type ID Field: N/A  Supported Interfaces:   REST  Supported Operations:   Query
What do you think is the problem here?
DominiqueBroux
Esri Frequent Contributor
I think I found out the issue.
It's because your shape field is called SHAPE (uppercase) and the Find sample is looking for an attribute called "Shape".
switch (graphic.Attributes["Shape"].ToString()) .....
If you replace "SHAPE" by "Shape" that will work for your second service (but no more for the first one).
The test can be more generic:
if (graphic.Geometry is Polygon)     graphic.Symbol = LayoutRoot.Resources["DefaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol; else if (graphic.Geometry is Polyline)     graphic.Symbol = LayoutRoot.Resources["DefaultLineSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol; else if (graphic.Geometry is MapPoint)     graphic.Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
should work in both cases.
DominiqueBroux
In your non working case, it looks like the field used for the rendering (i.e. 'Enabled') is not published by the service.
Check that your service is not hiding that field.
If you have no access to the service, the client workaround might to define your own renderer at the client side, for example a SimpleRenderer using the same symbol for all features.
MattMiley
I'm pretty sure the service isn't hiding it, whenever I add it as a ArcGISDynamicMapServiceLayer it shows up just fine with all the published symbology.
DominiqueBroux
Fields:
Type ID Field: N/A
'Enabled' doesn't seem to be in the list of published fields.
ArcGISDynamicMapServiceLayer shows up fine because the rendering is done at the server side and doesn't need any published fields.
MattMiley
Sorry to be miss leading, but the post only allowed for 1000 characters in this forum so i had to remove some things. Here is what the hydrants page looks like.
Type: Feature Layer
Description:
Copyright Text:
Min. Scale: 10000
Max. Scale: 0
Extent:
Drawing Info:
    Renderer:
        Field 1: Enabled
        Field 2:
        Field 3:
        Field Delimiter: ,
        Default Symbol:
            Unsupported Symbol
        Default Label:
        Unique Value Infos:
            Value: 0
            Label: False
            Description:
            Symbol:
            Value: 1
            Label: True
            Description:
            Symbol:
    Transparency: 0
    Labeling Info:
        Symbol:
            Simple Text Symbol:
            Type: esriTS
            Angle: 0
            XOffset: 0
            YOffset: 0
            Font Family: Arial
            Font Size: 8
            Font Style: normal
            Font Weight: bold
        Min. Scale: 0
        Max. Scale: 0
Fields:
    Model (Type: esriFieldTypeString, Alias: Model, Length: 32 )
    Ownership (Type: esriFieldTypeString, Alias: Ownership, Length: 32 )
    DrawingSet_ID (Type: esriFieldTypeInteger, Alias: DrawingSet_ID)
    DrawingSheet (Type: esriFieldTypeString, Alias: DrawingSheet, Length: 8 )
    SHAPE (Type: esriFieldTypeGeometry, Alias: SHAPE)
    Enabled (Type: esriFieldTypeSmallInteger, Alias: Enabled, Domain: Coded Values: [0: False], [1: True] )
    SOURCE_DESCRIPTION (Type: esriFieldTypeString, Alias: SOURCE_DESCRIPTION, Length: 64 )
    FOLDER (Type: esriFieldTypeString, Alias: FOLDER, Length: 128 )
    Location (Type: esriFieldTypeString, Alias: Location, Length: 255 )
Type ID Field: N/A
This used to work with the water features before I made the symbols based on enabled. Therefore I thought that does have something to do with it. Then I did published the features again without any custom symbology and it didn't work still, so I'm just lost now.
DominiqueBroux
OK looks good.
Try to define a renderer at the client side to know if it's a rendering issue.
You could also look at the requests sent to the server with fiddler (or any HTTP sniffer), that might give a clue.
MattMiley
OK looks good.
contains true
f json
layers 0,1,2,3
returnGeometry true
searchFields OBJECTID
searchText 111
sr 102100
Cache-Control private
Content-Encoding gzip
Content-Length 895
Content-Type text/plain;charset=utf-8
Date Thu, 29 Mar 2012 13:53:03 GMT
Etag -204973084
Server Microsoft-IIS/7.5
X-Powered-By ASP.NET
Request Headersview source
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Encoding gzip, deflate
Accept-Language en-us,en;q=0.5
Connection keep-alive
Host XXXXXXXX
User-Agent Mozilla/5.0 (Windows NT 6.1; WOW64; rv:10.0.2) Gecko/20100101 Firefox/10.0.2
I have confirmed that its not the symbology, i published the water and storm again with default symbology and again storm worked and water didn't. I know the water is made up of a geomatic network and the storm is not. Can that have something to do with it?
DominiqueBroux
Content-Length 895
Looks small for features (just enough to define your 14 fields).
Are you sure some features are returned from the server? Might be a query issue.
MattMiley
Here is the query request
http://XXXXXX/ArcGIS/rest/services/Water_Utilities_Map/MapServer/find?searchText=5400&contains=true&returnGeometry=true&sr=102100&searchFields=HydrantNumber%2cValveNumber%2cMeter_Number%2cLateral_Number%2cPipe_Number&layers=0%2c1%2c2%2c3%2c4%2c5%2c6%2c7%2c8&f=pjson&
Here is the response
  "results" : [
      "layerId" : 1,
      "foundFieldName" : "ValveNumber",
      "value" : "V5400n",
      "attributes" : {
        "OBJECTID" : "4116",
        "ValveNumber" : "V5400n",
        "ValveType" : "Null",
        "YearInstalled" : "Null",
        "Manufacturer" : "Null",
        "Model" : "Null",
        "Ownership" : "Lorain",
        "DrawingSet_ID" : "2",
        "DwgSheet" : "1",
        "StartNode_ID" : "Null",
        "SHAPE" : "Point",
        "Enabled" : "True",
        "SOURCE_DESCRIPTION" : "Null",
        "FOLDER" : "Null",
        "Location" : "Null",
        "Turns" : "Null",
        "DirectionOpen" : "Null",
        "Valve_Diameter" : "Null"
      "geometry" :
        "x" : -9148438.16978488,
        "y" : 5081889.88472851,
          "wkid" : 102100
MattMiley
I do spatial queries on the features and it works fine.
Here is a spatial query working on water and adding graphics layers after i select an item in the listbox.
[ATTACH=CONFIG]13102[/ATTACH]
But when i do a find on the map service I get the results but no graphics are made once i select the item in the listbox.
[ATTACH=CONFIG]13103[/ATTACH]
Which sample would show me the easiest way to define a renderer at the client side to know if it's a rendering issue?
