SL versions & ArcGIS versions
1032
01-13-2014 07:40 AM
AngelGonzalez
Simple question but could not find an answer in the documentations. Is the SL versions independent of the ArcGIS versions? That is can I use SL 3.2 with ArcGIS 10.1? Can I use SL3.1 with 10.2? 10.2.1?
DominiqueBroux
Esri Frequent Contributor
Yes the versions are independent.
You can use any SL version with ArcGIS 9.3 and +.
Obviously for taking advantage of a new functionality,  you need at least the server and the associated SL versions that implement the new functionality.
DominiqueBroux
