Single Quote in Query Task - Failure
6673
06-07-2011 05:48 AM
LakshmananVenkatesan
All,
Whenever we do a query task with column value having a single quote ESRI query task fails. We are using 2.1 version. Please let us know if there is any solution for this.
Thanks
SR
Thanks. Solution Found, we need to add another single quote
user = 'OU=BOIS D''XYZ EXPLORATION ABC,DC=HIGH2010W,DC=COM'
DominiqueBroux
Esri Frequent Contributor
As the single quote is used as string delimiter, you have to escape it if you want it inside a string.
Something like:
   query.Where = "City = 'Bois D\'Arcy' ";
Are you talking about this case or something else?
It is failing still : Sample
user = 'OU=BOIS D\'XYZ EXPLORATION ABC,DC=HIGH2010W,DC=COM'
YousefQuran
Thank you, it works fine!
