Silverlight4 &  Which .Net Framework to use????
2723
11
04-19-2010 12:40 PM
AngelGonzalez
Questions to you silverlight experts.  What .Net framework should I use to develop Silverlight4 app. in?
I created  a simple helloworld SL4 app and deployed it to a server and it blew up due to the fact my app. was targeting the .Net 4.0 and the server did not have it. I changed the framework to 3.5SP1 (which is on the server and it worked).  To take advantage of the new SL4 functionality and with the upcoming ESRI SL 2.0 version do I need the .Net 4.0 Framework or can everything be done in 3.5SP1 Framework?
Note, I am a beginner in SL  and just installed VS2010 on a test machine.
Angel
dotMorten_esri
Esri Notable Contributor
Your solution is to run your WCF website in a separate app-pool from ArcGIS Server. Only this apppool should run on .NET 4. Leave the app-pool that ArcGIS Server runs in at .NET 3.5
PLadd
Thanks Morton.  That's perfect.  Just the advice I needed to figure this one out.  It works great now.
For those who are novices with IIS like I am, here's a link to set up an application pool: http://www.developer.com/net/asp/article.php/2245511/IIS-and-ASPNET-The-Application-Pool.htm
Then go to the properties for your web app in IIS and repoint your application pool on bottom of Directory tab.
