Silverlight printing sample
25853
52
05-25-2011 11:22 AM
DanDong
Hi everyone,
I am using the silverlight printing sample from code gallery (http://www.arcgis.com/home/item.html?id=e361c2cc69784fcba34358d0458f66e3).
According to the ReadMe, I should add a reference to the MapPrintingControls.dll (located at
MapPrintingControls/Bin/Release) to my silverlight application.
But I cannot find MapPrintingControls.dll in that path and neither the whole download folder, thus I cannot add this reference. Does anyone has clue for this? or if you have the dll, could you please share it with me 🙂 Really appreciate.
deleted-user-ATjHIWsdQYmT
I haven't looked at the download, but I imaging if you build the solution (in release mode) it'll create the DLL for you.
tomw
You should be able to find from MapPrintingControls/obj/Release. You may like to add MapPrintingControls project to your solution, this way you will be able to modify it.
Hope this help.
DominiqueBroux
Esri Frequent Contributor
Andrew is right. The dll's are not provided in the zip. You must build the solution to create them.
DanDong
Hey guys, thank you! I build the application and find the dll file in the release folder. 🙂
DanDong
Sorry I have to ask another question. How can I change the template of the print dialog? Like in this screen shot [ATTACH]6851[/ATTACH]. In the bottom part, I think I don't need such options:
Rotate Map:
Page 1/3
Print to Scale
I kinda want to delete the textblock, checkbox and slidebar....
Is there some place that I can change them? If they are from a style, could you please share the style template? I don't have the blend...Thank you 🙂
DominiqueBroux
You have to retemplate the MapPrinterDialog. The default style is provided with the sources in MapPrinterDialog.Theme.xaml
DanDong
Hey Dominique, thank you 🙂 I found the template in MapPrinterDialog.Theme.xaml. Should I add this file via Add-Add existing item in my application? I tried this and I changed this line
mlns:local="clr-namespace:ESRI.ArcGIS.Client.Samples.MapPrinting"
to xmlns:controls="clr-namespace:ESRI.ArcGIS.Client.Samples.MapPrinting;assembly=MapPrintingControls" since the first one has an error.
I also changed "local" in <local:LogConverter x:Key="logConverter" /> to "controls" and the other "local" in the xaml.
But I still cannot see the layout of the printerdialog, it says: Internationally left blank, the document root element is not supported by the visual designer.
Did I miss something? or should I change the template in other ways instead of add the existing item? Thank you!
DominiqueBroux
There are a few ways to achieve that. The simplest is this one:
1) Copy the LogConverter and MapPrinterDialog style to the resources of your main page.
2) Change the local namespace to controls
3) Give a key to the MapPrinterDialog style
4) Change the style as you want
5) Use this style for your MapPrinterDialog
Something like:
  <UserControl.Resources>
    <controls:LogConverter x;Key="logConverter" />
    <Style x:Key="myMapPrinterDialogStyle" TargetType="controls:MapPrinterDialog">
    <controls:MapPrinterDialog Style="{StaticResource myMapPrinterDialogStyle}" ...
DanDong
Hey Dominique, thank you, that works very well 🙂 I successfully did it!
I want to use the printer style with legend which I have found in the sample codes. I have two questions here. I attach a screenshot here [ATTACH]6931[/ATTACH]
1. In the map frame, the map has been zoomed in, but in the print page the map doesn't zoom in (stays the Illinois state) leaving only a red rectangle in the northwest part (sorry,,,,it's very small...) as the area that will be printed. I see from your sample, when hitting the toggle button, the print dialog show again with a refreshed scale. In my application, I actually use a button (not a toggle button) to show the print dialog. Is there a way to get a zoomed map in the print dialog?
2. There is a difference between the two legends in the screenshot. I use the 'layerids' to limit the layers displayed in the legend. But I didn't find the similar thing in the legend in the printer style. So in the printer dialog, the legend side display all of the layers in my application. Is there a place in the printer style I can limit the 'layerids'?
Thank you! 😄
