Silverlight Print Sample:Usage
1387
04-21-2014 06:53 PM
HushamHassan
could you please put me in the right direction,  is it possible to use silverlight 3.0 Print sample in a separate xaml page and link it Main XAML page, because my Mainpage XAML is getting bigger.
if its possible could you mention how to do that.
Regards
AsserSwelam1
Yes sure, you can create a silverlight user control and add your printing code to it and then use it in the MainPage.xaml.
Here is a link for another printing sample http://www.arcgis.com/home/item.html?id=e361c2cc69784fcba34358d0458f66e3 conatin user controls and custom controls. Download link http://www.arcgis.com/sharing/rest/content/items/5d1b3c7e56a74466b5eea343ff92eca0/data
Also attached for you a simple code shows how to create a user control and link it to the MainPage.xaml
Asser
AsserSwelam1
Asser
HushamHassan
Asser,  Many thanks,   the link you provide is for SL5, I am using SL4 with API 3.0,  I am getting some error regarding Busy Indicator.
Your example is helpful.
Thank you again for your time and help.
Regards
HushamHassan
Thank you I solved it-  it's was the dll references.
Many thanks
