Silverlight Legend control with uniqueValue
764
02-08-2011 06:33 AM
AlirezaAhmadi
I like to show the name of the field that has uniqueValues. I can see the name of the field as "defaultLabel" in REST but I do not know how to bind it inside esri:Legend.MapLayerTemplate.
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer/0?f=json&pretty=true
I tried this :
                                       <StackPanel Orientation="Vertical">
                                            <TextBlock Text="{Binding Layer.defaultLabel}"
                                                       FontWeight="Bold"
                                                       VerticalAlignment="Center" />
                                        </StackPanel>
but it did not work.
JenniferNery
I'm not sure how you could construct a Binding statement directly, you might need to write a converter for this.
Label comes from the UniqueValueRenderer http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.UniqueValu.... Renderer from the GraphicsLayer can be of any Renderer type that implements IRenderer. http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.GraphicsLa...
You can try this code after the layer is Initialized and see that you can retrieve this value.
GraphicsLayer MyGraphicsLayer = sender as GraphicsLayer;
if (MyGraphicsLayer.Renderer is UniqueValueRenderer)
 UniqueValueRenderer renderer = MyGraphicsLayer.Renderer as UniqueValueRenderer;
 string label = renderer.DefaultLabel;
 foreach (var info in renderer.Infos)
  label = info.Label;
You can create a converter that accepts layer and value so that when you can break from the loop when a matching value is found (info.Value == parameterValue).
