silverlight cann't display a Arcgis map service,already copy the file
3379
08-14-2012 06:30 AM
XINGMIN
i have publiched an ArcGis map service using Arcgis server installed on
my own computer,the map service runs correctly in the Arcgis Server Manager
(can see the little map when you expand the service node).But a new-builded
silverlight application can not display the map!i have already copy the
fileclientaccesspolicy.xml to the web server(IIS) root dictionary:
C:\inetpub\wwwroot,the following is the XAML:
<UserControl x:Class="SilverlightApplication.MainPage"
  xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
  xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
  xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
  <Grid x:Name="LayoutRoot">
    <esri:Map x:Name="MyMap" >
      <esri:ArcGISTiledMapServiceLayer ID="MyMapLayer"
        Url="http://minxing/ArcGIS//services/binhai/MapServer"/>
    </esri:Map>
  </Grid>
</UserControl>
   thanks very much!
JMcNeil
When you hit the rest end point
http://yourservername/arcgis/rest/services
and click on the service you published
Then click View In ArcGIS JavaScript
Can you see the map with that?  Can you view the source code?  If you can then I think it might be your silverlight app code.
Jay
JMcNeil
YOu have two slashes in you address
I also think you need to add the word rest
http://minxing/ArcGIS/rest/services/binhai/MapServer
Jay
XINGMIN
http://minxing/ArcGIS //services/binhai/MapServer
Jay
I really appreciate you.my problem have already been handled.THANKS VERY MUCH!
i made a mistake when writing here using "//" after "ArcGIS",but it is right in my program xaml file.
i followed you step to "view in ArcGIS Javascript" then see the javascript code .i found that it used the "ArcGISDynamicMapServiceLayer" but not "ArcGISTiledMapServiceLayer".i changed my xaml code following it and also add "rest",then i saw the Map!
Thanks again! but i can not understand why it must be "ArcGISDynamicMapServiceLayer".do you know that?
XINGMIN
    I got the distinguish between the two layers now.
    Jay,thank you so much!
