ShowCoordinatesBehavior
897
01-05-2012 01:57 AM
MuhammadWaqar_ul_islam
i m using ShowCoordinatesBehavior sample version 2.2
my map projection is UTM 42N map unit are in meters its working fine
showing map coordinate on mouse move
i also  want to display map units in decimal degree on mouse move
is it possible
if yes then how i can display
DominiqueBroux
Esri Frequent Contributor
To convert UTM 42N to geoegraphical coordinates you need either to write your own projection code, or to use a geometry service at the server side (see sample).
However, using a projection service on mouse move might be too slow (should work well on mouse click though).
