'show only layers visible at current scale' setting not honored on initial map load
942
10-09-2013 03:45 AM
TerryRichards
I have created a silverlight viewer that has the  'show only layers visible at current scale' setting checked but when the map first loads all layers are visible in the Map Contents. It is only once the user has zoomed in or out for the first time that the layers not visible at that scale disappear.
ErwinSoekianto
Esri Alum
You may need to set the zoom/scale in the initial map load.
