Setting the Map or Layer DPI?
2036
11-14-2011 10:41 AM
GregoryDillon
I have a PDF export feature that uses the SilverPDF library.   I want to improve the output quality on the pipes displayed in the PDF (which is ultimately printed out).   This is a dynamic layer.   I believe in order to do this we would need to set the DPI on the map or the layer itself rather than the PDF page or document.    Where do I set the DPI on the map or layer (I can't find the property)?    Am I correct in that the fix would be needed on the map's or layer's DPI rather than the PDF (if its the PDF where is this setting)?
DominiqueBroux
Esri Frequent Contributor
There is no DPI property for the map or for the layer.
A dynamic layer requests always an image having the size of the map on the screen.
We can try to include your map in a smaller viewbox. In this case, the images will still have the size of the map, but this will have a better definition  in the viewbox.
Though, note that you will quickly run into an ArcGIS server limitation: the size of a dynamic layer image is limited to 2048*2048.
GregoryDillon
What did you mean by "We can try to include your map in a smaller viewbox"?
I actually don't use the screen map when I print, but rather create a new print version of the map with the same size as the page (the user pick the page size from a dropdown).  I then rebuild the print map by adding print versions of ArcGISDynamicMapServiceLayer (pointing to print version of web services) that are equivalent to the layer currently visible on the screen map.    I was hoping to set the DPI on the print version of the map.
I think this might be what you are suggesting or hints at it.   Or are you suggesting something else?   Sorry I got a little confused by you last response.
DominiqueBroux
Sorry I was unclear (and furthermore I am not sure it's a good idea so... :().
What I meant is that you might create a Viewbox with the same size of the page and include in this viewbox a map having twice (for example) the size of the page. This will change the scale of the map.
Easier to understand with a sample. The left part is the map without viewbox and the right part is the map inside a viewbox.
<Grid x:Name="LayoutRoot" >
    <Grid.ColumnDefinitions>
        <ColumnDefinition Width="*" />
    </Grid.ColumnDefinitions>
    <esri:Map x:Name="MyMap"  WrapAround="True" Grid.Column="0" Height="400" Width="400">
        <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
            Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            InitializationFailed="Layer_InitializationFailed" />
        <esri:ArcGISDynamicMapServiceLayer ID="DynamicLayer"
            Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/RecentEarthquakesRendered/Map..."
    </esri:Map>
    <Viewbox Grid.Column="1" Height="400" Width="400">
        <esri:Map x:Name="MyMap2"  WrapAround="True" Height="800" Width="800">
        </esri:Map>
    </Viewbox>
</Grid>
