Setting Renderer on feature layer by code
3520
07-29-2010 07:49 AM
MarcoRosa
Hi to all, i've this case:
if i set simple renderer on xaml this work fine ,
    <esri:SimpleRenderer x:Key="DefaultFillRenderer">
    <esri:SimpleRenderer.Symbol>
                    <esriSymbols:SimpleFillSymbol BorderBrush="Blue" Fill="#330000FF" />
                </esri:SimpleRenderer.Symbol>
            </esri:SimpleRenderer>
if i set renderer throught code does't work ....
FeatureLayer dyn_ftlyr = new FeatureLayer();
dyn_ftlyr.ID = "MyFeatureLayer";
dyn_ftlyr.ID = "MyUrl";
dyn_ftlyr.Renderer = LayoutRoot.Resources["DefaultFillRenderer"] as SimpleRenderer ;
Where is my error ? thankkkkssss
DominiqueBroux
Esri Frequent Contributor
I guess it's just a typo and that you are initializing the Url method and not the ID
Did you verify in debug that the renderer is not null?
MarcoRosa
hi dominique , that's true .... renderer its null.
it's wrong the way to set the renderer ?
DominiqueBroux
The Renderer can be set this way but it needs to be defined in the resources.
In your case, it looks like the "DefaultFillRenderer" is not defined in the resources of the Layout grid.
