Server 10 samples
1191
10-05-2010 07:37 AM
DonFreeman
Has ESRI provided new Silverlight samples for ArcServer 10.0? Some of the code from the old samples is producing errors that say the code is obsolete, et. al.
Thanks
JenniferNery
Are you referring to samples from: http://esriurl.com/slsdk2 ?
Which sample? Thanks.
DonFreeman
Nope. I was looking at http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/samples/start.htm .
Thanks for the pointer to the other site. I will look and see if there is different code. The problem I was seeing is a statement that this line:
 <esriConverters:DictionaryConverter x:Name="MyDictionaryConverter" />
is obsolete.
JenniferNery
Yes that is correct the DictionaryConverter has been marked obsolete since Silverlight 4 has support for binding into dictionaries i.e. {Binding [AttributeKey]}.
