Secured service with https
1110
11-29-2012 05:58 PM
DeminHu
In ArcGIS Server 10.1, when I use a secured service, in .xaml file, I do the following like:
<esri:ArcGISDynamicMapServiceLayer ID="TestLayer", Url="http://mydomain/arcgis/rest/services/TestSv/MapServer" Token="XXXmnbgh-456xxxxxxx" />
It works fine.
But recently I set up  ArcGIS Server system with Reverse Proxy server, set the Urls as https.
When I use the following:
<esri:ArcGISDynamicMapServiceLayer ID="TestLayer", Url="https://proxydomain/arcgis/rest/services/TestSv/MapServer" Token="XXXmnbvhk-476xxxxxxx" />
Even the token is valid, but it doesn't work.
I tried SignInDialog sample with https, it didn't work either ( I already applied SP1 and security patch).
http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#SignInDialogSimple
any help ?
Thanks.
DeminHu
The problem seems solved, I made a silly mistaken.
The page  with https map serivices should be opened with HTTPS, not http.
