ScaleLine control hide US units
961
01-31-2012 10:42 PM
DavideLimosani
hi all,
I have a noob question for you. How can I hide the US units on the ScaleLine? I'd like to keep only meters and kilometers. I don't think that the API reference is clear on this point, but probably I'm missing something.
Thank you in advance!
Davide
DominiqueBroux
Esri Frequent Contributor
You have to change the style of the scaleline.
For example, here is a ScaleLine template showing only Metrics Units, localizing the units and displaying the text in the center of the scale line:
<esri:ScaleLine.Template>
    <ControlTemplate TargetType="esri:ScaleLine">
        <Grid x:Name="LayoutRoot">
            <Grid.Resources>
                <converters:ObjectToObjectConverter x:Key="UnitsConverter">
                    <ResourceDictionary>
                        <sys:String x:Key="Meters">Métres</sys:String>
                        <sys:String x:Key="Kilometers">Kilométres</sys:String>
                    </ResourceDictionary>
                </converters:ObjectToObjectConverter>
            </Grid.Resources>
            <StackPanel HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" >
                <StackPanel x:Name="MetricNotchs" Orientation="Horizontal">
                    <Rectangle x:Name="LeftTopNotch" Width="2" Fill="{TemplateBinding Foreground}" Height="5" Stroke="{TemplateBinding Foreground}" VerticalAlignment="Bottom" />
                    <Grid Width="{Binding MetricSize, RelativeSource={RelativeSource TemplatedParent}}">
                        <StackPanel x:Name="MetricText" Orientation="Horizontal" HorizontalAlignment="Center" >
                            <TextBlock Text="{Binding MetricValue, RelativeSource={RelativeSource TemplatedParent}}"/>
                            <TextBlock Text="{Binding MetricUnit, RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource UnitsConverter}}"/>
                        </StackPanel>
                    </Grid>
                    <Rectangle x:Name="RightTopNotch" Width="2" Fill="{TemplateBinding Foreground}" Height="5" Stroke="{TemplateBinding Foreground}" VerticalAlignment="Bottom"/>
                </StackPanel>
                <StackPanel x:Name="ScaleLineBlock" Orientation="Horizontal">
                    <Rectangle x:Name="NotchsWidth" Fill="{TemplateBinding Foreground}" Height="2" Stroke="{TemplateBinding Foreground}" Width="4"/>
                    <Rectangle Fill="{TemplateBinding Foreground}" Height="2" Stroke="{TemplateBinding Foreground}" Margin="0" HorizontalAlignment="Left"
                                Width="{Binding MetricSize, RelativeSource={RelativeSource TemplatedParent}}" />
                </StackPanel>
                <StackPanel x:Name="BottomNotchs" Orientation="Horizontal">
                    <Rectangle x:Name="LeftBottomNotch" Width="2" Fill="{TemplateBinding Foreground}" Height="5" Stroke="{TemplateBinding Foreground}" VerticalAlignment="Top" />
                    <Grid x:Name="PaddingLeftBottomNotch" Width="{Binding MetricSize, RelativeSource={RelativeSource TemplatedParent}}" />
                    <Rectangle x:Name="RightBottomNotch" Width="2" Fill="{TemplateBinding Foreground}" Height="5"  Stroke="{TemplateBinding Foreground}" VerticalAlignment="Top"/>
                </StackPanel>
            </StackPanel>
        </Grid>
    </ControlTemplate>
</esri:ScaleLine.Template>
