Scalebar does not display
1168
10-29-2010 09:39 AM
ChrisBradberry
Hey,
I am using the glass template, and the scalebar works before I customize it.  When I changed to my map service, the scalebar quit working.  My map service is a custom projection, but I stated the WKID and the extent.  will changing the map service projection disable the scalebar?
Is there some setting that I am missing?
Chris
JenniferNery
ChrisBradberry
Jennifer,
I looked at that, but I have already upgraded to silverlight api v2.0.   Off and on it seems like the scalebar is really squished into the right side of the scalebar area.
Chris
ChrisBradberry
I figured out that the map units were set at decimal degrees, so I added the mapunit to the navigator callout in xaml and it worked fine.
<localtoolkit:Navigator x:Name="nav" Map="{Binding ElementName=Map}" HorizontalAlignment="Left" Loaded="nav_Loaded" Grid.Row="1" d:LayoutOverrides="Height" Grid.RowSpan="2" MapUnit="Feet"/>
Chris
