Routing Error
3322
03-13-2012 03:15 AM
MuhammadWaqar_ul_islam
I have create Na Routing service sample to test
but its gives error
"Routing error: Unable to complete operation unable to find atribute invalid Context"
but on arcgis info its works fine
i have attached gdb in Northkarachi.gdb.rar
for u testing
help me out what i m doing wrong
services properties
Network Layer: Route
Layer Type: esriNAServerRouteLayer
Impedance: Meters
Restrictions: Oneway, RestrictedTurn
Accumulate Attribute Names:
Attribute Parameter Values:
Use Hierarchy: false
Hierarchy Attribute Name:
Hierarchy Level Count: 0
Hierarchy Max Values:
Hierarchy Num Transitions:
Snap Tolerance: 0
Max Snap Tolerance: 5000
Snap Tolerance Units: esriMeters
Ignore Invalid Locations: true
Restrict U-Turns: esriNFSBAllowBacktrack
Output Spatial Reference: 32642
Find Best Sequence: false
Use Start Time: false
Start Time: Sat, 30 Dec 1899 08:00:00 GMT
Use Time Windows: false
Preserve First Stop: true
Preserve Last Stop: true
Output Line Type: esriNAOutputLineTrueShape
Directions Language: en-US
Direction Style Names: NA Desktop, NA Navigation
Directions Length Units: esriNAUMiles
Directions Time Attribute:
Network Analysis Classes:
Class Name: Stops
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Address, Label, Location, Stop, WayPoint, Description, Title, DepotName
Field Name: RouteName
Default Value:
Candidate Fields: RouteName, Route, RouteID
Field Name: Sequence
Default Value: 1
Candidate Fields:
Field Name: TimeWindowStart
Default Value:
Candidate Fields: TimeWindowStart1, TWStart1, FromTime1, FromTimeWindow1, FromTW1, From1, TimeWindowStart, TWStart, FromTime, FromTimeWindow, FromTW, From
Field Name: TimeWindowEnd
Default Value:
Candidate Fields: TimeWindowEnd1, TWEnd1, ToTime1, ToTimeWindow1, ToTW1, To1, TimeWindowEnd, TWEnd, ToTime, ToTimeWindow, ToTW, To
Field Name: SourceID
Default Value: -1
Candidate Fields: SourceID, SID, Source
Field Name: SourceOID
Default Value: -1
Candidate Fields: SourceOID, SOID
Field Name: PosAlong
Default Value: 0
Candidate Fields: PosAlong, PA, Pos
Field Name: SideOfEdge
Default Value: 2
Candidate Fields: SideOfEdge, SOE
Field Name: CurbApproach
Default Value: 0
Candidate Fields: CurbApproach, SideOfStreet, SideApproach, CurbSide, Curb
Field Name: Status
Default Value: 0
Candidate Fields:
Field Name: Attr_Meters
Default Value: 0
Candidate Fields: Attr_Meters, Meters
Class Name: Barriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Address, Label, Location, Barrier, Description, Title
Default Value: -1
Default Value: -1
Default Value: 0
Default Value: 2
Default Value: 0
Field Name: Status
Default Value: 0
Candidate Fields:
Field Name: FullEdge
Default Value: 0
Candidate Fields: FullEdge, IsFullEdge, BlockEntire
Field Name: BarrierType
Default Value: 0
Candidate Fields: BarrierType, BarType, BarrierTyp
Default Value: 0
Class Name: PolylineBarriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Candidate Fields: Name, Label, Locations, Barrier, Description, Title
Field Name: Locations
Default Value:
Candidate Fields: Locations, LocRanges
Default Value: 0
Default Value: 1
Class Name: PolygonBarriers
Field Name: Shape
Default Value:
Candidate Fields:
Field Name: Name
Default Value:
Default Value:
Default Value: 0
Default Value: 1
Network Dataset: RoadNetWork_ND
Network Attributes:
Meters
Usage Type: esriNAUTCost
Units: esriNAUMeters
Data Type: esriNADTDouble
Parameter Names:
Oneway
Usage Type: esriNAUTRestriction
Units: esriNAUUnknown
Data Type: esriNADTBoolean
Parameter Names:
RoadClass
Usage Type: esriNAUTDescriptor
Data Type: esriNADTInteger
Parameter Names:
RestrictedTurn
Parameter Names:
Network Sources:
Street
Element Type: esriNETEdge
Source Type:esriNSTEdgeFeature
RoadNetWork_ND_Junctions
Element Type: esriNETJunction
Source Type:esriNSTSystemJunction
RestrictedTurns
Element Type: esriNETTurn
Source Type:esriNSTTurnFeature
Supported Operations:   Solve Route
JenniferNery
You might get a response from this forum, kindly post here: http://forums.arcgis.com/forums/102-Network-Analyst
Dear All Esri Member
i m working on this error unable to find attribute on Network Analysis (Routing) services for many
On the above message reply by esri member i have been forward to Network Analysis forum
Now i have been forward back to this forum
Re: NA Route Rest services gives error
Muhammad,
From your previous message it looks like you have already gotten a valid route back from the server.
The only step is left is to make your Silverlight application send the same HTTP parameters to the server endpoint: use RouteTask, RouteParameters, and RouteResult classes from the ESRI.ArcGIS.Client.Tasks namespace.
Here is a good sample how to use route endpoint in Silverlight: http://help.arcgis.com/en/webapi/sil...rt.htm#Routing
Dmitry
Can any one solved this issue
i have arcgis server install on my laptop and i have check rest services
http://localhost/ArcGISSERVER/rest/services/NA/karachi/NAServer/Route/solve
it provided the answer
but when i used on arcgis any api it gives error mention above
What kind of error is this that can not be solved
hope some one reply with answer
dmacq
Just some info for anybody that comes across this thread looking to a solution for the above mentioned error.  I had the same problem. I could route with the ESRI service, but my own would throw an error.  It works fine in ArcMap, and as a service in a separate Flex application.
I was able to fix the issue by setting UseHierarchy to False in the RouteParameters of the SolveAsync method of the route task. Hopefully this helps somebody.
JavierCatalán_Herrero
Thank you very much DrewGIS, I have fixed my problem (after trying many issues for hours) setting Hierarchy to false.
