Rotate arrow symbol based on the direction of location point
2219
08-23-2014 11:47 PM
JulieBiju
I can Rotated an arrow with the code I mentioned below. Is it possible to rotate a car icon with the same code? I need to rotate the DefaultCArSymbol based on direction  instead of MyRotatingMarkerSymbol. For that How can I write the code?Pls HELP ME
  esri:PictureMarkerSymbol x:Key="DefaultCArSymbol" OffsetX="8" OffsetY="8" Source="/ESRI-V-10-SIL4;component/Images/car-red-16x16.png" />
            <esri:MarkerSymbol x:Name="MyRotatingMarkerSymbol" OffsetX="6" OffsetY="3">
                <esri:MarkerSymbol.ControlTemplate>
                    <ControlTemplate>
                        <Grid x:Name="ArrowGrid" RenderTransformOrigin="0.5,0.5" Background="Transparent" Width="6" Height="12">
                            <Path Data="M2.625,11.5 L0.5,9.375 L1.88125,9.375 L1.88125,0.5 L3.3687501,0.5 L3.3687501,9.375 L4.75,9.375 z"
                                  Fill="#FFF4F4F5" Margin="0.625,0.25,0.625,0.625" Stretch="Fill" Stroke="Black" UseLayoutRounding="False"/>
                            <Grid.RenderTransform>
                                <CompositeTransform Rotation="{Binding Attributes[WIND_DIRECT]}" ScaleX="2" ScaleY="2" />
                            </Grid.RenderTransform>
                        </Grid>
                    </ControlTemplate>
                </esri:MarkerSymbol.ControlTemplate>
            </esri:MarkerSymbol
AsserSwelam1
Hi Julie,
You can use the Angle property of the PictureMarkerSymbol.
Asser
AsserSwelam1
Hi Julie,
Asser
