Relationship ID
10170
13
08-24-2011 10:51 AM
DavidKelly1
I am new to Silverlight.  I am trying to convert the live sample in the ArcGIS API for Silverlight to run with my data.  The sample I am using is the related records sample.  I need to have the relationship ID, it says to find it in the sertvice directory.  What does that mean? How
Thanks for your help,
David
DominiqueBroux
Esri Frequent Contributor
What should I do to set Relationship ID?
When I look through Services Directory rest point at may mapservice I do not see Relationshps: at all.
You need to add the tables/feature classes the relationships are based on to your map before publishing it..
januszkrawczynski
Once, the relashionship is set.
How can I test it make sure it works?
How do I find RelationshipID?
Janusz
DominiqueBroux
Janusz
You can send a request to the feature service end point. You should see the relationships ID defined for the service: example.
januszkrawczynski
Got it.
Janusz
