Reg : Usage of ArcObjects in Silverlight
1045
11-05-2010 12:41 PM
VikramS
Hi all ,
Can anyone share me an example how to use arcobjects in Silverlight application . That would be a great help .. Thanks a bunch
dotMorten_esri
Esri Notable Contributor
ArcObjects is not supported by Silverlight.
If you need to execute some ArcObjects code, you will need to create a custom webservice on the server and call that.
This blogpost might help get you started : http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/03/11/Sending-geometry-between-Silverlig...
AlexeiB
Hi Morten,
Has this changed in VS 2012 and Arc 10.2 or do I still need to create a custom web service?
LanceCrumbliss
Hi Morten,
I'm sure this hasn't changed.  ArcObjects is an a huge API compiled for development using full blown .NET and it wouldn't be practical to port to Silverlight.
