Get coordinates of box drawn for spatial query
2757
09-16-2013 01:04 PM
AlexCarnes1
First off, I am completely new to creating add-ins for the Silverlight Viewer. I am trying to edit an existing code that allows the user to draw a box to spatially query a layer. I'd like to be able get the coordinates of the box that is drawn, and display them in a popup box. Any ideas? Below is the code that I am working with at present, that queries and spits out a graphics layer.
using System;
using System.ComponentModel.Composition;
using System.Windows;
using System.Windows.Input;
using System.Windows.Media;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Extensibility;
using ESRI.ArcGIS.Client.Symbols;
using ESRI.ArcGIS.Client.Tasks;
using System.Windows.Controls;
namespace SpatialQuery.AddIns
    [Export(typeof(ICommand))]
    [DisplayNameAttribute("Draw Box for Database Query")]
    public class SpatialQueryTool : IToggleCommand
        private Draw drawObject;
        private bool isChecked;
        public SpatialQueryTool()
            isChecked = false;
            // Initialize the draw object that will be used to draw the query box
            drawObject = new Draw(MapApplication.Current.Map)
                LineSymbol = new LineSymbol() { Color = new SolidColorBrush(Colors.Red), Width = 2 },
                FillSymbol = new FillSymbol()
                    Fill = new SolidColorBrush(Color.FromArgb(125, 255, 0, 0)),
                    BorderBrush = new SolidColorBrush(Colors.Red)
                DrawMode = DrawMode.Rectangle,
                IsEnabled = false
            drawObject.DrawComplete += drawObject_DrawComplete;
        #region IToggleCommand Members
        public bool CanExecute(object parameter)
            if (MapApplication.Current.SelectedLayer is FeatureLayer)
                return true;
            else
                return false;
        public void Execute(object parameter)
            // Toggle the checked state of the command
            isChecked = !isChecked;
            OnCanExecuteChanged();
            // Enable/disable the draw object based on the checked state
            drawObject.IsEnabled = isChecked;
            if (isChecked)
                // Use ShowWindow instead of MessageBox.  There is a bug with
                // Firefox 3.6 that crashes Silverlight when using MessageBox.Show.
                MapApplication.Current.ShowWindow("Query Features", new TextBlock()
                    Text = "Draw box for DRSCW database Query",
                    TextWrapping = TextWrapping.Wrap,
                    Margin = new Thickness(30),
                    MaxWidth = 480
        public bool IsChecked()
            return isChecked;
        public event EventHandler CanExecuteChanged;
        #endregion
        protected virtual void OnCanExecuteChanged()
            if (CanExecuteChanged != null)
                CanExecuteChanged(this, EventArgs.Empty);
        private void drawObject_DrawComplete(object sender, DrawEventArgs args)
            // Untoggle the command and disable the draw object
            isChecked = false;
            drawObject.IsEnabled = false;
            // Query the selected layer with the user-drawn geometry
            ESRI.ArcGIS.Client.Geometry.Geometry geometry = args.Geometry;
            QueryData(geometry);
        private void QueryData(ESRI.ArcGIS.Client.Geometry.Geometry geometry)
            // Initialize the query
            Query query = new Query() { ReturnGeometry = true };
            query.OutFields.Add("*");
            query.Geometry = geometry;
            query.OutSpatialReference = MapApplication.Current.Map.SpatialReference;
            string serviceURL = null;
                serviceURL = ((FeatureLayer)MapApplication.Current.SelectedLayer).Url;
            QueryTask queryTask = new QueryTask(serviceURL);
            // Hook to the query's completed event handlers
            queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
            queryTask.Failed += QueryTask_Failed;
            // Execute the query
            queryTask.ExecuteAsync(query);
        private void QueryTask_ExecuteCompleted(object sender, QueryEventArgs args)
            // Check whether any results were found
            FeatureSet featureSet = args.FeatureSet;
            if (featureSet == null || featureSet.Features.Count < 1)
                MapApplication.Current.ShowWindow("Error", new TextBlock()
                    Text = "Out of bounds",
                    MaxWidth = 480
                return;
            else
                MapApplication.Current.ShowWindow("Success", new TextBlock()
                    Text = "Features Found",
                    MaxWidth = 480
            // Retrieve or create a graphics layer to use for displaying results
            GraphicsLayer graphicsLayer = null;
            if (featureSet.Features[0].Geometry is ESRI.ArcGIS.Client.Geometry.MapPoint)
                graphicsLayer = GetOrCreateLayer("Point Query Results");
            else if (featureSet.Features[0].Geometry is ESRI.ArcGIS.Client.Geometry.Polyline)
                graphicsLayer = GetOrCreateLayer("Polyline Query Results");
            else if (featureSet.Features[0].Geometry is ESRI.ArcGIS.Client.Geometry.Polygon)
                graphicsLayer = GetOrCreateLayer("Polygon Query Results");
            // Add the results to the graphics layer
            graphicsLayer.ClearGraphics();
            foreach (Graphic feature in featureSet.Features)
                graphicsLayer.Graphics.Add(feature);
            // If the layer has not already been added to the map, add it
            if (MapApplication.Current.Map.Layers[graphicsLayer.ID] == null)
                MapApplication.Current.Map.Layers.Add(graphicsLayer);
        // If a graphics layer with the specified ID already exists in the map, retrieve it.  Otherwise, create it.
        private GraphicsLayer GetOrCreateLayer(string layerId)
            Layer layer = MapApplication.Current.Map.Layers[layerId];
            if (layer != null && layer is GraphicsLayer)
                return layer as GraphicsLayer;
            else
                GraphicsLayer gLayer = new GraphicsLayer() { ID = layerId };
                gLayer.SetValue(MapApplication.LayerNameProperty, layerId);
                return gLayer;
        private void QueryTask_Failed(object sender, TaskFailedEventArgs args)
                Text = "Query failed. The service may not support query or the service is not available.",
                MaxWidth = 480
LanceCrumbliss
This is the Silverlight API forum.  You want the Silverlight Viewer forum.
http://forums.arcgis.com/forums/211-ArcGIS-Viewer-for-Silverlight
