Refreshing ArcGISDynamicMapServiceLayer
2741
04-03-2011 08:28 AM
MahshavaMahshava
I have an ArcGISDynamicMapServiceLayer with 20 vector layers.
When someone adds (or deletes) a feature to a layer (in code via ArcObjects, not REST API), I want to see the new feature on the Map automatically.
I've tried to use the methods:
ArcGISDynamicMapServiceLayer.Refresh() and
ArcGISDynamicMapServiceLayer.Initialize()
but they don't help me.
How can I make the Map to refresh in code and display the new feature (or remove the old one)?
Thanks!
DominiqueBroux
Esri Frequent Contributor
'Refresh' should do the trick but  set 'DisableClientCaching' to true in order to avoid issue with images that could be in the browser cache.
Note : Check also that your map service is not cached else your modifications won't be taken into account before rebuilding the server cache.
MahshavaMahshava
Thanks, I set DisableClientCaching to true and it worked 🙂
