Refresh WMS Layer
6133
12
06-15-2010 12:30 PM
BrianGustafson
I have a timer set up so that at each tick the WMS layer(weather radar) will update.  When I use the refresh method the WMS is not updated until I pan the map.  Is there some other way to update WMS layers without needing to pan the map?
DanielWalton
Put it in:
public override void GetUrl(Envelope extent, int width, int height, DynamicMapServiceLayer.OnUrlComplete onComplete)
Esri provides the source to these classes because they know folks will want to modify them. So go ahead and modify 🙂
samulineuvonen
OK, I was able to get it working. Thanks to you, Dan!
Also, I think I was able to implement some sort of control over the queueing requests, not by Javascrit but by using the LostFocus- and GotFocus-events of the MainPage (RootVisual) and another timer checking if the focus was lost and not returned for more than 5 seconds (in which case the actual timer was stopped). We'll see how this works in production...
Thanks again,
Samuli
samulineuvonen
One more update to this, although a bit of topic: I was able to use this same approach to implement a sort-of "TimeAware" WMS layer. I added both a property named "Autorefresh" and the code below in the GetURL-function in the WMS.cs and then created a custom TimeSlider-control, which updates the VisibleTimeExtent-property of the referenced WMS layers. Seems to work nicely, so just in case someone else is trying to solve this...
S
if (this.Autorefresh==true)
    //autorefresh
    mapURL.AppendFormat("&t={0:hhmmss}", DateTime.Now);
else if (this.VisibleTimeExtent != null)
    if (this.VisibleTimeExtent.Start == this.VisibleTimeExtent.End)
        mapURL.AppendFormat("&TIME={0:yyyy-MM-ddTHH:mm:ss.sssZ}", this.VisibleTimeExtent.Start);
    else
        mapURL.AppendFormat("&TIME={0:yyyy-MM-ddTHH:mm:ss.sssZ}/{1:yyyy-MM-ddTHH:mm:ss.sssZ}", this.VisibleTimeExtent.Start, this.VisibleTimeExtent.End);
