Refresh WMS Layer
1631
6
02-29-2012 11:23 AM
JayKappy
I am trying to refresh a WMS weather Layer....
its not refreshing....read soemthing about disableCache or something...
What am I missing?
Thanks
<esri:WmsLayer ID="Nexrad" Url="http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?" Version="1.3.0"
      SkipGetCapabilities="True" Initialized="Nexrad_Initialized" Opacity=".5"  Visible="True" />
    Private Sub UserControl_Loaded(ByVal sender As Object, ByVal e As RoutedEventArgs)
        ' Timer to refresh Weather
        Dim localTimer As New DispatcherTimer()
        AddHandler localTimer.Tick, AddressOf localTimer_Tick
        localTimer.Interval = New TimeSpan(0, 0, 30)
    End Sub
    Private Sub localTimer_Tick(ByVal sender As Object, ByVal e As EventArgs)
        Dim nexradWmsLayer As ESRI.ArcGIS.Client.Toolkit.DataSources.WmsLayer = Nothing
        nexradWmsLayer = TryCast(MyMap.Layers("Nexrad"), ESRI.ArcGIS.Client.Toolkit.DataSources.WmsLayer)
        nexradWmsLayer.Refresh()
    End Sub
    Private Sub Nexrad_Initialized(ByVal sender As System.Object, ByVal e As System.EventArgs)
        Dim VisibleWmsLayers As String() = {"nexrad-n0r-900913-m05m"}
        nexradWmsLayer.Layers = VisibleWmsLayers
    End Sub
JayKappy
Something like this
nexradWmsLayer.DisableClientCaching = True
I try the below but get an error that the DisableClientCaching is not a member of Toolkit.DataSources.WMSLayer
    End Sub
JayKappy
I placed a msgbox on the timer and It never fires...
        MessageBox.Show("timer")
        ' Refresh the layer
    End Sub
I also placed a button on the form adn this code./....the messagebox fires but does not seem to refresh....
<Button x:Name="Refresh"  Width="20" Height="20" Content="x" FontSize="8"
          Click="RefreshWeather" Foreground="Black" Effect="{StaticResource miniDropShadow}" Margin="0,0,20,0"/>
    Private Sub RefreshWeather(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs)
        MessageBox.Show("Refresh Button")
        ' Refresh the layer
    End Sub
JayKappy
I changed the code to this and I am now getting the timer to work as the messagebox fires....BUT the WMS layer IS NOT refreshing...
If I uncomment these two lines the layer Aerials is set to false and disappears..
        'Dim arcgisLayer As ArcGISTiledMapServiceLayer = TryCast(MyMap.Layers("Aerials"), ArcGISTiledMapServiceLayer)
        'arcgisLayer.Visible = False
Why wont the WMS layer Refresh?
        timerNew = New DispatcherTimer()
        timerNew.Interval = TimeSpan.FromMilliseconds(3000)
        AddHandler timerNew.Tick, AddressOf timer_OnTickNew
    End Sub
    Private Sub timer_OnTickNew(ByVal sender As Object, ByVal e As EventArgs)
        MessageBox.Show("New timers")
        ' Refresh the layer
    End Sub
JayKappy
Can I even refresh a WMS layer?  Puzzled here...is it getting cached?
I dont get an error now but the WMS weather service does not refresh...
I have to close the app wait a few seconds and then reopen and it refreshes..
hmmmmmmm
THanks
JenniferNery
What are you trying to accomplish with Refresh() anyway? Every time the map extent changes, WMS layer will try to re-draw using GetUrl().
samulineuvonen
Hello,
Just replying to Jennifers question: Wouldn't refresh be the ideal way to update e.g. the positions of moving vehicles provided in a WMS without having the whole map to be redrawn? Or is there another way to have only one layer update? Or does refresh on one layer always refresh the whole map?
Regards,
Samuli
