OrderByFields
2692
02-06-2014 06:16 AM
JeffFrye
Good Morning,
I am attempting to order by multiple fields. Using the sample I can successfully get the sort to work in one field, but I want it to sort by 'Field A' and then 'Field B'. In the code below "FULLNAME" is my Field A and "PREADDRNUM" would be my Field B.
I have spent 2 days searching for a solution. I did find a C# version, but I have not been able to convert it properly.
Can someone help me with this?  Thank you
Dim addressQuery As Query = New ESRI.ArcGIS.Client.Tasks.Query()
        addressQuery.OutFields.Add("*")
        addressQuery.ReturnGeometry = True
        addressQuery.Text = AddressBox.Text
        addressQuery.OrderByFields = New List(Of OrderByField)() From {New OrderByField("FULLNAME", SortOrder.Ascending)}
        addressTask.ExecuteAsync(addressQuery)
I placed this SUB in here because in the C# version I saw the order was set in this event.
Private Sub FindTask_ExecuteCompleted(sender As Object, e As QueryEventArgs)
        AddressGrid.Visibility = Windows.Visibility.Visible
        Dim featureSet As FeatureSet = e.FeatureSet
        If featureSet IsNot Nothing AndAlso featureSet.Features.Count > 0 Then
            AddressGrid.ItemsSource = featureSet.Features
        Else
            MessageBox.Show("No features returned from query")
        End If
    End Sub
JeffFrye
I actually resolved this myself.
Place the second field behind the first one separated by a comma as such:
addressQuery.OrderByFields = New List(Of OrderByField)() From {New OrderByField("FULLNAME, PREADDRNUM", SortOrder.Ascending)}
