Refresh Graphics Layer
5515
07-23-2010 07:13 AM
by Anonymous User
Not applicable
Original User: ereed
I am using a dynamic map service that contains a point layer that changes frequently. I refresh the dynamic layer every 10 seconds, but the graphic that contains the map tip remains at the original location.If I remove the graphics from the graphicslayer, and recreate them, I see the graphics blink, but the show up at the original location. How do I get the graphics to refresh, and show up at the new location, just as is happening with the dynamic layer?
     public MainPage()
            InitializeComponent();
            DispatcherTimer timer = new DispatcherTimer() { Interval = TimeSpan.FromSeconds(10) };
            timer.Tick += (s, e) => { RefreshMap(); };
            timer.Start();
        private void RefreshMap()
            DynamicLayer dLayer;
            dLayer= (DynamicLayer)Map1.Layers["myLayer"];
            dLayer.Refresh();
            CreatePtGraphics();
        private void CreatePtGraphics()
            GraphicsLayer gLayer;
            gLayer = (GraphicsLayer)Map1.Layers["PtGraphicsLayer"];
            //gLayer.ClearGraphics();
            ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query()
                Geometry = new ESRI.ArcGIS.Client.Geometry.Envelope(-180, 0, 0, 90)
            query.OutFields.Add("*");
            QueryTask queryTask = new QueryTask("http://XXX/ArcGIS/rest/services/XXX/MapServer/0");
            queryTask.ExecuteCompleted += PtGraphicsLayerQueryTask_ExecuteCompleted;
            queryTask.ExecuteAsync(query);
            //gLayer.Refresh();
        void PtGraphicsLayerQueryTask_ExecuteCompleted(object sender, QueryEventArgs queryArgs)
            if (queryArgs.FeatureSet == null)
                return;
            FeatureSet resultFeatureSet = queryArgs.FeatureSet;
            ESRI.ArcGIS.Client.GraphicsLayer graphicsLayer =
            Map1.Layers["PtGraphicsLayer"] as ESRI.ArcGIS.Client.GraphicsLayer;
            if (resultFeatureSet != null && resultFeatureSet.Features.Count > 0)
                foreach (ESRI.ArcGIS.Client.Graphic graphicFeature in resultFeatureSet.Features)
                    graphicFeature.Symbol = DefaultMarkerSymbol;
                    graphicsLayer.Graphics.Add(graphicFeature);
JenniferNery
Looking at your code, you are trying to add graphics to a MapServer layer. This is read-only and any edits to it will not be applied, even if you refresh your dynamic layer.
Jennifer
by Anonymous User
Not applicable
Original User: dbroux
Might be a cache issue.
Try disabling the client cache :
queryTask.DisableClientCaching = true;
This will add a time stamp to the URL.
