Reference for editor from Viewer Tool
1098
07-27-2011 01:37 AM
GüntherGrill
I am trying to implement this sample in a ArcGIS Viewer Visual Studio Template project
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerSelection
I removed the map part, as the map is defined in the map.xaml in the web project.
I created a user control, modified the code so that the tools would appear after pressing the tool icon:
MapApplication.Current.ShowWindow("Select Range", view);
So far that works however, the functions are greyed out since they are not bound to the layers in the map. How can I bind the editor defined in the user control to the (all) layers in the map?
Günther
DominiqueBroux
Esri Frequent Contributor
If your question concerns the silverlight viewer, you may have more chance to get an answer by posting it in the beta forum.
