Raster Catalog Identify Image's Pixel Value?  (And Legend Not Showing?)
1158
11-01-2010 02:47 PM
RyanCoodey
We have a raster catalog served up that contains elevation data.  There is a new raster every 24 days with new data and so we use the time slider to scroll through these changes over time, hence the reason they are in a catalog and not standalone.
1) How can I get the pixel value for a spot the user clicks on the map?
     a) On a side note, does the identify task even return pixel values for standalone rasters?
2) The catalog layer has a classified renderer... I am using the code from ShapeGIS's legend service and it does not bring any symbology back.  I don't see that the different classified ranges are even available in the REST API either.  I think I saw that 10.1 server was going to have a legend service.  Know if it will show these?
Thanks a lot for any info!
dotMorten_esri
Esri Notable Contributor
1) Use the ImageServiceIdentifyTask to get pixel values.
2) That legend was never tested with / built for ImageService (you could probably enhance it to do that). It's not 10.1 but 10SP1 that will add legend support. However as far as I know, ImageServices are not supported.
RyanCoodey
Hey Morten, thanks a lot for the reply!
Heres the problem though, I am not using an ImageService, it is a DynamicMapServiceLayer... this is for a few reasons.
- Image Services do not support raster catalogs
- Mosaic Datasets (which are supported as Image Services) do not support applying classified symbology.
Therefor we serve up a map service that contains a raster catalog layer and not an image service.
Now we could apply the classified renderer to all our images and export them out with it and put those in a mosaic dataset, but we have a good amount of these images and if the classification needs to change, then these will all have to be exported again.
I tried using the ImageServiceIdentifyTask against the DynamicMapServiceLayer and got this error: "An unexpected error occurred processing the request."
Thanks for the info on the legend... SP1 is coming out in like a week or so, isnt it?  I'll have to check it out.  Again, this is not a Image Service though... just a regular map service.
Thanks for the help!
