Question for TextSymbol ControlTemplate
3345
01-29-2013 05:07 AM
ahlzl
WINXP SP3 + VS2010SP1 + Siverlight5 + API3.0
my XML code:
<UserControl xmlns:esri="http://schemas.esri.com/arcgis/client/2009"  x:Class="SL_TextSymbol.MainPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    mc:Ignorable="d"
    d:DesignHeight="300" d:DesignWidth="400">
    <Grid x:Name="LayoutRoot" Background="White">
        <Grid.Resources>
            <esri:SimpleMarkerSymbol x:Key="RedCircleSymbol" Color="Red" Size="12" Style="Circle" />
            <esri:TextSymbol x:Key="MyTextSymbol">
                <esri:TextSymbol.ControlTemplate>
                    <ControlTemplate>
                        <Border Background="White" BorderBrush="Black">
                            <TextBlock x:Name="MyInfo"
                                FontSize="{Binding Symbol.Size}"
                                Text="{Binding Symbol.Text}"
                                Foreground="Blue"
                                FontFamily="{Binding Symbol.FontFamily}"
                                HorizontalAlignment="Center" />
                        </Border>
                    </ControlTemplate>
                </esri:TextSymbol.ControlTemplate>
            </esri:TextSymbol>
        </Grid.Resources>
        <esri:Map x:Name="MyMap" WrapAround="True" Background="White">
            <esri:ArcGISTiledMapServiceLayer ID="PhysicalTiledLayer"
                Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
            <esri:GraphicsLayer ID="MyGraphicsLayer" />
        </esri:Map>
    </Grid>
</UserControl>
My C# code:
using System.Windows.Controls;
using System.Windows.Media;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Projection;
using ESRI.ArcGIS.Client.Symbols;
namespace SL_TextSymbol
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            // one
            Graphic graphic1 = new Graphic()
                Geometry = new MapPoint(118, 35),
                Symbol = LayoutRoot.Resources["RedCircleSymbol"] as Symbol
            graphicsLayer.Graphics.Add(graphic1);
            TextSymbol textSymbol1 = LayoutRoot.Resources["MyTextSymbol"] as TextSymbol;
            Graphic graphicText1 = new Graphic()
                Symbol = textSymbol1
            textSymbol1.FontSize = 12;
            textSymbol1.Foreground = new SolidColorBrush(Colors.Blue);
            textSymbol1.Text = "one";
            textSymbol1.OffsetX = -10;
            graphicsLayer.Graphics.Add(graphicText1);
            // two
            Graphic graphic2 = new Graphic()
                Geometry = new MapPoint(1800000, 50000),
            graphicsLayer.Graphics.Add(graphic2);
            TextSymbol textSymbol2 = LayoutRoot.Resources["MyTextSymbol"] as TextSymbol;
            Graphic graphicText2 = new Graphic()
                Symbol = textSymbol2
            textSymbol2.FontSize = 12;
            textSymbol2.Foreground = new SolidColorBrush(Colors.Blue);
            textSymbol2.Text = "two";
            textSymbol2.OffsetX = -10;
            graphicsLayer.Graphics.Add(graphicText2);
[ATTACH=CONFIG]21160[/ATTACH]
I want "one" and "two". but "two" and "two".
thanks!
DominiqueBroux
Esri Frequent Contributor
Despite different names, both variables point to the same text symbol.
When you change the symbol, your change applies to all graphics using this symbol, i.e all your graphics.
You should either create different symbols (if there are few possible Text values) or, likely better, bind the symbol Text to a graphic attribute, so you don't have to change the symbol. i.e something like:
            <esri:TextSymbol x:Key="MyTextSymbol" Text={Binding Attributes[myFieldUsedForLabelling]}>
                    <ControlTemplate>
                                Foreground="Blue"
                        </Border>
                    </ControlTemplate>
            </esri:TextSymbol>
or directly in the template:
                    <ControlTemplate>
                                Text="{Binding Attributes[myFieldUsedForLabelling]}"
                                Foreground="Blue"
                        </Border>
                    </ControlTemplate>
            </esri:TextSymbol>
ahlzl
                    <ControlTemplate>
                                Foreground="Blue"
                        </Border>
                    </ControlTemplate>
            </esri:TextSymbol>
                    <ControlTemplate>
                                Foreground="Blue"
                        </Border>
                    </ControlTemplate>
            </esri:TextSymbol>
succeed and thanks!
