QueryTask: OutStatistic returns error if calculated on SHAPE.LEN
3583
05-07-2014 01:52 AM
roufbaba
Hi
If using statistic capability of Query on SHAPE.LEN. It returns an error "Unable to complete operation". Can anybody provide me assistance in this matter.
Regards
Rouf
baohuachu3
Hi Rouf,
    I have the same problem. It may be the bugs of arcgisServer.
Here I describe it in detail.
  Environment:
       ArcGIS Server :10.2.2
      ArcGIS desktop for publish Service:10.1
     ArcSDE: 10.1
Issue:
       line feature in SDE published on Server. I want to get sum line length by some attribute.
On rest service page , set parameters for statistics. Click "query" button it returns "SUM(SHAPE.LEN) AS AAAA: xxxx".
AAAA-outStatisticFieldName.  The response of the request should be :AAAA: xxxx.
There is no Server API can get the value of SUM(SHAPE.LEN) AS AAAA:
   The screenshot of the rest service response is as the pic:
baohuachu3
According to local ESRI support the reason is :
    SDE is based on old version of Sqlserver(mine is 2005). Geometry data is stored as SDEBINARY type in SDE.
Geometry objects stored in shape and f table. The line length is calculated based on union query. So the query result is "sum(shape.len) as xxxx".
   The way to solve this is to use SQLServer 2008 or above.
