Query Related Records Modification
977
10-26-2012 12:52 PM
TanyaOwens
Hi all,
I am using the sample code from http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryRelatedRecords to query related records on my map. I would like to put in a condition that states if there is only 1 record selected to automatically display the related records in the treeview. I am, as usual stumped on how to do this. I am assuming it needs to be written into the SelectedItemChanged event, is this correct? If so, I am not seeing what is stopping the related data to automatically show up in the datagrid as it is now.
Thanks!!
GreggBreton
Hello Tanya,
You can try this
void QueryTask3_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            if (featureSet != null && featureSet.Features.Count > 0)
                SelectedSitesTreeView.Tag = featureSet.ObjectIdFieldName;
                SelectedSitesTreeView.ItemsSource = featureSet.Features;
                int count = 0;
                Graphic newValue = null;
                foreach (Graphic g in featureSet.Features)
                    g.Symbol = LayoutRoot.Resources["SelectMarkerSymbol"] as MarkerSymbol;
                    graphicsLayer.Graphics.Add(g);
                    newValue = g;
                    count = count + 1;
                SelectedSitesTreeView.Visibility = System.Windows.Visibility.Visible;
                // If there was only one graphic, change the data grid the value of this graphic/feature.
                if (count == 1)
                    RoutedPropertyChangedEventArgs<object> changedGraphics = new RoutedPropertyChangedEventArgs<object>(null, newValue);
                    SelectedSitesTreeView_SelectedItemChanged(sender, changedGraphics);
            else
                SelectedSitesTreeView.Visibility = System.Windows.Visibility.Collapsed;
                MessageBox.Show("No samples found here, please try another location.");
