Push Value from MapTip to VB
7108
30
06-14-2011 09:49 AM
JayKappy
I have a MapTip that is returning a value from a field....I need this value to be pushed to the VB code so I can do soemthing with it...
Can that be done...Say inthe Map Tip below I have this....when I click the Button it sends a Binding Value from a field to the VB Sub....
This is the field that I need the bound field value "{Binding [Field1]}" sent to the vb Sub "doThis" as seen below...
From a MapTip can I send a Binding Value to a VB sub ????
THanks
<!-- Snip inside MapTip of Feature -->
<StackPanel Orientation="Vertical">
 <Button x:Name="button" Background="Green" Width="40" Height="20" Content="button" Click="doThis"  SEND TO VB SUB="{Binding[Field1]}" />
</StackPanel>
<!-- Snip -->
IgressT
THanks
</StackPanel>
<!-- Snip -->
This works for me (code in C#)...
                        Background="Green"
                        Width="40"
                        Height="20"
                        Content="button"
                        Command="{Binding GetMapTipValue}"
                        CommandParameter="{Binding ElementName=MyMapTip}"
            </StackPanel>
            <!-- Snip -->
and in the command
        private RelayCommand<object> _getMapTipValue;
        public RelayCommand<object> GetMapTipValue
            get
                if (this._getMapTipValue == null)
                    this._getMapTipValue = new RelayCommand<object>(GetMapTipValueRelayMethod);
                return this._getMapTipValue;
        private void GetMapTipValueRelayMethod(object commandParameter)
            var result = (ESRI.ArcGIS.Client.Toolkit.MapTip)commandParameter;
            var result2 = (IDictionary<string, object>)result.ItemsSource;
            MessageBox.Show(result2["Field1"].ToString());
JayKappy
Thanks for your responce...I converted to VB but am getting errors on teh RelayCommand not being defined in VB..In RED below...
Do you have that defined above in your CS page?
   Private _getMapTipValue As RelayCommand(Of Object)
    Public ReadOnly Property GetMapTipValue() As RelayCommand(Of Object)
        Get
            If Me._getMapTipValue Is Nothing Then
                Me._getMapTipValue = New RelayCommand(Of Object)(AddressOf GetMapTipValueRelayMethod)
            End If
            Return Me._getMapTipValue
        End Get
    End Property
    Private Sub GetMapTipValueRelayMethod(ByVal commandParameter As Object)
        Dim result = DirectCast(commandParameter, ESRI.ArcGIS.Client.Toolkit.MapTip)
        Dim result2 = DirectCast(result.ItemsSource, IDictionary(Of String, Object))
        MessageBox.Show(result2("Field1").ToString())
    End Sub
IgressT
I am using the MVVM lite framework I am not sure if you are using it but you can create a ICommand and do the same thing...
JayKappy
Sort of lost me on that one....I tried this..and getting error...seems the error is on the Object...as there is a blue squiggly line under each....
System.Windows.Input.ICommand has no type parameters and so cannot have type arguments
THanks for your time and patience....
    Private _getMapTipValue As ICommand(Of Object)
    Public ReadOnly Property GetMapTipValue() As ICommand(Of Object)
        Get
                Me._getMapTipValue = New ICommand(Of Object)(AddressOf GetMapTipValueRelayMethod)
            End If
        End Get
    End Property
IgressT
Ok I will be clear...
In my XAML I have this
                    <Button Content="GetMapTipValue"
                            Height="30"
                            Width="150"
                            Command="{Binding MapTipValueCommand}"
                            CommandParameter="{Binding ElementName=MyMapTip}">
                    </Button>
In my ViewModel class I have this
       private MapTipValueCommand mapTipValueCommand;
        public MapTipValueCommand MapTipValueCommand
            get
                if (this.mapTipValueCommand == null)
                    this.mapTipValueCommand = new MapTipValueCommand();
                return this.mapTipValueCommand;
my command class looks like this
public class MapTipValueCommand:ICommand
        public bool CanExecute(object parameter)
            return true;
        public event EventHandler CanExecuteChanged;
        public void Execute(object parameter)
            var result = (ESRI.ArcGIS.Client.Toolkit.MapTip)parameter;
            MessageBox.Show(result2["XXX"].ToString());
JayKappy
I really appreciate your help with this....I am not a wiz by any means, as you can already see....
I have a project that already has a bunch of code in it xaml adn vb. I have a couple classes in the vb code so placing this code is challenging...
XAML:
<!--  Snip from Map Tip  -->
<Button x:Name="bTurnOn3"  Background="Red" Width="40" Height="20" Content="TurnON" Click="bTurnOn_Click3"
       CommandParameter="{Binding ElementName=MyMapTip}"/>
VB: Right in the middle of my vb code that exists, where all the other code is I placed this
    Private m_mapTipValueCommand As MapTipValueCommand
    Public ReadOnly Property MapTipValueCommand() As MapTipValueCommand
        Get
            If Me.m_mapTipValueCommand Is Nothing Then
                Me.m_mapTipValueCommand = New MapTipValueCommand()
            End If
            Return Me.m_mapTipValueCommand
        End Get
    End Property
Then at the bottom I created the new class with this: Although I get an error on the Implements ICommand:
ERRORS:
Class 'MapTipValueCommand' must implement 'Sub Execute(parameter As Object)' for interface 'System.Windows.Input.ICommand'.
Class 'MapTipValueCommand' must implement 'Function CanExecute(parameter As Object) As Boolean' for interface 'System.Windows.Input.ICommand'.
Class 'MapTipValueCommand' must implement 'Event CanExecuteChanged(sender As Object, e As EventArgs)' for interface 'System.Windows.Input.ICommand'.
Public Class MapTipValueCommand
    Implements ICommand
    Public Function CanExecute(ByVal parameter As Object) As Boolean
        Return True
    End Function
    Public Event CanExecuteChanged As EventHandler
    Public Sub Execute(ByVal parameter As Object)
        Dim result = DirectCast(parameter, ESRI.ArcGIS.Client.Toolkit.MapTip)
    End Sub
End Class
IgressT
Try something like this...
    Implements ICommand
    Public Function CanExecute(parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged(sender As Object, e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(parameter As Object) Implements System.Windows.Input.ICommand.Execute
    End Sub
End Class
JayKappy
No errors there so we are getting close....although the message box does not appear when I click the button in the Map Tip....
This is what I have so far...for some reason the message box wont open...
I additionally added a message box in the ReadOnly Porperty that was placed inthe main vb code area....the message box is not being fired off....
No Message Box pops up giving me the value of Field1...
I THANK YOU VERY Much for your help...it is very appreciated...
Thoughts? Something that I can focus on? does the command parameter element name have to reflect something else?
XAML:
<esri:FeatureLayer ID="Stops" Visible="False"
Url="http://gi.org/arcgis/rest/services/MG_Test/MapServer/8"
       Renderer="{StaticResource BusStopUniqueRenderer}">
   <esri:FeatureLayer.OutFields>
        <sys:String>Video</sys:String>
   </esri:FeatureLayer.OutFields>
   <esri:FeatureLayer.MapTip >
       <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" CornerRadius="10"
              BorderBrush="#FF222957" BorderThickness="0" Margin="0,0,15,15">
       <Border.Background>
       <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188">
           <GradientStop Color="#FFD1DFF2"/>
           <GradientStop Color="#FF092959" Offset="0.946"/>
       </LinearGradientBrush>
       </Border.Background>
       <Border.Effect>
           <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" />
       </Border.Effect>
       <Grid>
           <StackPanel Orientation="Vertical" Margin="10,10,0,10" VerticalAlignment="Center">
              <Grid>
                      Width="100" Height="20"
              </Grid>
           </StackPanel>
       </Grid>
       </Border>
   </esri:FeatureLayer.MapTip>
</esri:FeatureLayer>
VB Code that sits where all the main vb code currently exists
        Get
            End If
            MessageBox.Show("In the Get")
        End Get
    End Property
VB Code placed outside the main code creating a new class.
    Implements ICommand
    Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute
        MessageBox.Show(result2("Video").ToString())
    End Sub
End Class
IgressT
See the attached project (its in C#, build the solution to run it)
