Proxy.ashx Security
1119
09-12-2011 07:29 AM
DanielSanders
I have a Silverlight application that makes use of the proxy.ashx & proxy.config files provided by ESRI. A comment at the top of the proxy.ashx flie reads:
  This proxy page does not have any security checks. It is highly recommended
  that a user deploying this proxy page on their web server, add appropriate
  security checks, for example checking request path, username/password, target
  url, etc.
I have mustMatch set to true in proxy.config, so that should handle the target url. None of the urls have usernames and passwords. Other than that I can't think of "security checks" to add. Does anyone have any suggestions or examples of other security checks that could be implemented? For instance, how could the request path be checked?
Thanks....
RichardWatson
We have a custom proxy.  The proxy will only forward requests from authenticated users that target resources known by the proxy.  One common trick is for someone to use a proxy to forward requests to servers having nothing to do with your application.  If you want to do this then just check if the target URL matches the base URL of resources you expose.
DanielSanders
Thanks for the information.
