Proj.NET and 102100 Projection
3981
6
06-15-2010 06:42 AM
DanielWalton
I am using the ProjNET library to do reprojection in the client for popular coordinate systems. When I try to specify 102100 as a destination coordinate system (using several variant WKT's), the points always have a y-error of about 20km (in SoCal). Is there anyone out there who has successfully modified this library (I'm guessing with a shift grid) to support 102100 as a destination? I really would like to be able to drop the ESRI.ArcGIS.Client.Bing.dll from my project references!
Dan
dotMorten_esri
Esri Notable Contributor
What is the from coordinate system?
On a side note, webmercator projection will be in the core API at the next release, so you won't need Bing by then (it will also support reprojecting entire geometries and not just points)
DanielWalton
Source projections are lat/long (KML) and various Albers projections (shapefiles). They all seem to have the same y-error and all show up fine in 4326.
-Dan
dotMorten_esri
Are they all using the WGS84 datum? If not, I don't think you will have much luck with anything but the projection service.
DanielWalton
Why not? Obviously the ESRI.ArcGIS.Client.Bing library is able to do this in the client. Is it proprietary ?
Dan
dotMorten_esri
No it's not able to do a datum transform. The input MUST be EPSG:4326, or it will throw an exception.
http://help.arcgis.com/en/webapi/silverlight/apiref/topic2392.html
DanielWalton
Yes, all my test cases use the WGS84 datum. Using the Bing assembly they all visualize correctly over a 102100 map service, and with ProjNet they all show up 20km south.
Dan
