ESRI Standard Map Template - Where?
921
06-15-2010 09:20 AM
ShaningYu
Honored Contributor
In http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/help/index.html, it mentions the ESRI Standard Map Template.  However, there is no hyperlink for its source code.  Does anyone know how to get it?  Please share.  Thanks.
dotMorten_esri
Esri Notable Contributor
Create a new project in Visual Studio or Blend, and select the standard map template there in the Silverlight\ESRI category.
If you don't have this option, it's because you didn't have either Blend or the (free) Blend SDK installed when you installed the API.
