Programmatically fire DrawComplete Event
1288
06-15-2012 06:01 AM
RobertMEIER
When drawing a line I want to fire the DrawComplete event after the user clicks a second point, essentially overriding the double-click to end drawing.
this is VB -
it is my understanding that you can finr the event just by doing this: GraphicDrawObject_DrawComplete(Nothing, arg)
the issue is I can't set the geometry of the DrawEventArgs - I get something like this: set accessor of property is not accessible
The documentation say that is is a setable property - below is the code I am tryinh
  Dim pl As ESRI.ArcGIS.Client.Geometry.Polyline = New ESRI.ArcGIS.Client.Geometry.Polyline()
  pl.SpatialReference = MainMap.SpatialReference
  pl.Paths.Add(ptsCurrent)
  Dim arg As ESRI.ArcGIS.Client.DrawEventArgs = New ESRI.ArcGIS.Client.DrawEventArgs()
arg.Geometry = pl (this line error)
Any help is appreciated!
-bert
JoeHershman
There is a CompleteDraw() method on the Draw object.  Just call that on your second click and it will fire off the Draw.Complete event.
-Joe
JoeHershman
-Joe
RobertMEIER
Joe, that works!
Thanks for pointing me in that direction.
-bert
