Programatically pan left or right
1012
06-07-2010 11:08 PM
xariaD
How to attach pan left, pan right capabilities to custom image navigator?
DominiqueBroux
Esri Frequent Contributor
Depending on what you are doing, you could:
1) Customize the navigation control provided in the toolkit. In Blend:
[INDENT]- insert the navigation control[/INDENT]
[INDENT]- right click on it[/INDENT]
[INDENT]- choose 'Edit Template'  and then 'Edit a copy'[/INDENT]
[INDENT]- change the look as you need.[/INDENT]
2) Programmatically in C# use  the ZoomTo method on the map.
3) In XAML, use the PanToAction (example : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#NavigationActions)
OrenGal
use PanTo() of the map
Oren
DominiqueBroux
You are right Oren, I made a mistake. The method to pan is 'PanTo' and not 'ZoomTo'.
Sorry about that.
