Problems with Graphics Layer
1467
08-30-2010 10:26 AM
JorgeBerumen
Hello there.
I am currently working with the ArcGIS Silverlight API v2.0 alongside ArcGIS Server 9.3.1. Right now I am following one of the tutorials in the Samples site - the custom symbols example. I try the code using the server provided and works wonderfully, however, when I switch over to my map service the map doesn't show up neither does the graphics layer (everything is white). Is there an incompatibility here? Why am I having this problem? Here is the simple code:
Working
<Grid x:Name="LayoutRoot" Background="White">
        <Grid.Resources>
             <esri:SimpleMarkerSymbol x:Key="RedMarkerSymbol" Color="Red" Size="12" Style="Circle" />
        </Grid.Resources>
        <esri:Map x:Name="MyMap" Background="White">
            <esri:ArcGISTiledMapServiceLayer ID="PhysicalTiledLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/NPS_Physical_World_2D/MapServer"/>
            <esri:GraphicsLayer ID="MyGraphics" >
                <esri:GraphicsLayer.Graphics >
                    <esri:Graphic Symbol="{StaticResource RedMarkerSymbol}" >
                        <esri:MapPoint X="0" Y="0" />
                    </esri:Graphic>
                </esri:GraphicsLayer.Graphics>
            </esri:GraphicsLayer>
        </esri:Map>
    </Grid>
</UserControl>
Not working:
        <Grid.Resources>
        </Grid.Resources>
            <esri:ArcGISTiledMapServiceLayer ID="PhysicalTiledLayer" Url="http://myserver/ArcGIS/rest/services/Storm"/>
                    </esri:Graphic>
        </esri:Map>
    </Grid>
</UserControl>
Thanks in advance!
egismazeika
You should always check the url in the browser first.
This time try http://myserver/ArcGIS/rest/services/Storm/MapServer
JorgeBerumen
This time try   http://myserver/ArcGIS/rest/services/Storm /MapServer
I apologize - I hand-edited the URL to prevent disclosing my actual server. The server URL is fine. I know so because I've attempted the project without the graphics layer and with the graphics layer. It works without but not with a graphics layer. Can someone please help me?
egismazeika
GraphicsLayer code is fine and is has nothing to do with errors you get. This is your server (service) problem.
JorgeBerumen
What do you think is wrong? I've attempted to recreate the service all together and the same thing occurs. What options should I modify?
Thanks!
