Problems about maptip.
995
04-18-2011 08:03 AM
weiliang
I have one point feature layer with maptip defined and one polygon graphic layer without maptip associated. The problem is that if my mouse hover over the polygon graphic layer, the maptip for the point feature layer will disappear immediately (this is not what I want). Is there anyway that I can prevent this happening (i.e., deactivate the maptip functionality for polygon graphic layer)?
Thanks for your input,
Wei
JenniferNery
Thank you for your feedback. You are right this is the current behavior - when you enter another graphic, regardless if it had map tip set, the current map tip will close. We are considering to include your enhancement request in the future.
weiliang
Thanks for your feedback, Jennifer.
Best,
Wei
