Problem with Where clause
1165
04-23-2013 11:52 AM
DonFreeman
What are the limitations with the WHERE clause of a FeatureLayer? I need to embed some SQL into it but my attempt to use the LIKE operator seems to not work. See below:
<esri:FeatureLayer ID="FutureLines"
 DisableClientCaching="False"
 Url="http://gismaps.pagnet.org/ArcGIS/rest/services/TipData/MapServer/1"
 OutFields="*"
 Where="RtaID Like 'RTA*' and (DevelopmentStatus='Not Started' or DevelopmentStatus='On Hold')"
 Renderer="{StaticResource FutureLinesRenderer}"
Ultimately I will also need to parse out an integer value from the 5th and 6th characters of the RtaID. The format is like this: 'RTA-34a'. I need to display the features where the first 3 characters are 'RTA' and the integer value of the 5th and 6th is less than 35. Can someone help me out here?
DonFreeman
Yikes! I had the wildcard wrong. Now this works in SSMS
 where (RtaID LIKE 'RTA%' and convert(integer,SUBSTRING(RtaID,5,2)) < 36) and (DevelopmentStatus='Not Started' or DevelopmentStatus='On Hold')
but how can I use it in the FeatureLayer Where clause? The less than symbol seems to be the problem.
