Problem with QueryTask and geometry
1115
05-17-2010 10:58 AM
SebastienPelletier
When I perform a querytash the features result have always geometry at nothing
Code :
Dim Task As New ESRI.ArcGIS.Client.Tasks.QueryTask()
       Task.Url = "http://server/arcgis/rest/services/xxx/MapServer/8"
        Dim Query As New ESRI.ArcGIS.Client.Tasks.Query
        Query.ReturnGeometry = True
        Query.Where = txtQuery.Text
        AddHandler RequeteTask.ExecuteCompleted, AddressOf QueryComplete
        AddHandler RequeteTask.Failed, AddressOf QueryError
        Task.ExecuteAsync(Query)
Private Sub QueryComplete(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.Tasks.QueryEventArgs)
         For Each Feature As ESRI.ArcGIS.Client.Graphic In args.FeatureSet.Features
           ' BUG here Feature.Geometry is always nothing
    End Sub
SebastienPelletier
I found the problem, but not the solution.
The problem occurs when my featureclass has a Global ID (UUID) field . When I delete the field everything works.
dotMorten_esri
Esri Notable Contributor
If you go to the rest endpoint and execute the same query from the HTML page, do you get geometry back?
SebastienPelletier
I found the problem, the field shape was set to invisible in the mxd
Thank you
